How much data do you actually collect during log gathering?Solved
8 months ago Mar 16, 2026
Hey all,
We’re starting to use remote log collection more actively for troubleshooting and a few security investigations, but I feel like we’re a bit all over the place with what we collect.
Sometimes we just grab everything “just in case,” and other times we keep it minimal and end up missing something important. How do you usually decide the right scope before running a collection?
Replies (9)
Yeah, this is a pretty common problem. Early on, we used to just dump everything—system logs, app logs, configs, the whole lot. Sounds safe, but it quickly becomes messy. Huge files, harder analysis, and most of it ends up unused.
Now we try to be more intentional depending on the issue.
You are right, @carter! We had a case where a device was behaving oddly, and we only pulled basic system logs. Turned out the issue was tied to a background service, and the only useful info was in process-level data + app logs. Had to rerun the whole thing.
After that, we started mapping “issue → required data” before collecting anything.
That makes sense. So you don’t follow any standard checklist?
8 months ago Mar 17, 2026
There’s kind of a loose baseline most teams follow:
  • System logs for OS-level stuff
  • Application logs for crashes or failures
  • Network info for connectivity issues
  • Process/service details
  • Device configuration data
 But it’s more like a starting point, not something you always collect fully.
Also depends on how you’re collecting. With scripts, you can go super granular. Specific folders, log files, and even filtered outputs. That’s what we use most of the time.
For ChromeOS, though, it’s more of a packaged thing. You pick options, but it’s not as flexible.
Yeah, ChromeOS logs are good when you want a quick snapshot without overthinking it. But for deeper investigations, scripts are way better.
8 months ago Mar 18, 2026
Got it. So the scope is basically something you define, not something fixed by default.
Exactly. Think of it like this “collect just enough to answer your question”. Anything extra just slows you down later.
+1. The tricky part isn’t collecting logs, it’s collecting the right logs.
