how do we strictly enforce and lock data roaming on samsung deployments?Solved
10 months ago Jan 22, 2026
We are deploying a massive fleet of Samsung tablets equipped with global eSIMs. The entire project relies on these devices seamlessly switching cellular networks across different borders. The major problem is that end users keep going into the settings and manually turning off data roaming to save battery, which completely severs our remote management access. Is there an actual bulletproof way to force data roaming ON and permanently lock the setting so users cannot touch it?
10 months ago Jan 23, 2026
Since your fleet is entirely Samsung hardware, you should absolutely use the Knox Service Plugin. It is the gold standard for locking down specific device settings. Navigate to Policies, select Android, choose Knox Service Plugin, and click Configure. You can enable the data roaming policy directly through that plugin. Since it is a Knox level command, it pushes the configuration straight to the system architecture and should enforce your requirement.
10 months ago Jan 24, 2026
I appreciate the navigation paths, but I actually just finished testing that exact method with our QA team. We pushed the policy to our Samsung devices, and while it successfully flipped the data roaming toggle to ON, it did not gray out or lock the setting at all! The user is still completely free to manually turn it back OFF. Did we miss a secondary lockdown step in the configuration?
10 months ago Jan 26, 2026
You did not miss a step at all. @mo-chou gave you the correct standard procedure, but you just collided with a known vendor level limitation.
While the plugin is supposed to be the ultimate lockdown tool, forcing data roaming into a permanently locked ON state is just not fully supported within the Knox Service Plugin right now. It executes the initial state change to ON, but it completely fails to gray out the user interface element.
Because the plugin is built, updated, and maintained entirely by Samsung, this is fundamentally a Samsung defect rather than an MDM issue. Your best path forward is to raise a support ticket directly with Samsung Knox and report the UI failure. Until they patch the plugin on their end, there is no magic secondary step to stop users from overriding it.
