Hexnode enrollment error: device limit reached when adding new devicesSolved
2 days ago Nov 24, 2026
I’m trying to enroll a few new devices in Hexnode, but the devices keep showing a “device limit reached” error during enrollment. I can see enrolled devices in the portal dashboard, and I already disenrolled a couple of old devices, but the error still appears on new devices. Is there a place in Hexnode where I can confirm how many devices my account can enroll and whether I’ve hit the limit?
Hi @hugo_l,
This message usually appears when the number of enrolled devices has reached the device license limit available for the portal.
You can check your total licensed device count by navigating to Admin → License in the Hexnode UEM portal.
If the enrolled device count is at the licensed limit, new enrollments will be blocked until a license slot becomes available.
A few things to verify:
  1. Check the total number of device licenses available for the portal.
  2. Compare it with the number of currently enrolled devices.
  3. Review whether there are any inactive, partially enrolled, or no longer used devices still consuming license slots.
  4. Disenroll devices that are no longer required.
  5. If you need to enroll more devices than the current license count, add more device licenses from the portal by navigating to Profile menu > Billing > Add devices.
Once additional licenses are added, or unused devices are removed, the new devices should be able to enroll without the “device limit reached” error.
So even if a device is inactive or was only partially enrolled, it can still count toward the device limit until it is removed or disenrolled?
