De-bugging Your Options: Flexible USB Debugging Controls in Android Policies!Solved
4 months ago Jul 21, 2026
Hello,
We are excited to share a new update that brings flexibility to your Android policy management!
When it comes to managing device restrictions, we know that administrative controls aren’t always black and white. Up until now, configuring USB Debugging under your Android Advanced Restrictions was a simple on/off checkbox. To give you much finer operational control—whether you’re securing corporate devices or supporting developer teams—we’ve upgraded this setting into a versatile dropdown!
To explore this change, navigate to Policies > Android > Restrictions > Advanced > Allow settings and locate USB Debugging.
Instead of a simple checkbox, you now have three distinct choices to fit your specific security and workflow requirements:
  • User can choose (Default): Keeps things flexible by allowing the end-user to toggle USB debugging on or off from the device settings as needed.
  • Always ON: Keeps USB debugging continuously enabled—perfect for developer devices, specialized hardware, or dedicated testing environments.
  • Always OFF: Enforces a strict security stance by locking down USB debugging completely, protecting your devices against unauthorized data transfers and connections.
Whether you need tight security lock-downs or open environments for development, this update ensures your USB debugging policies hit the exact sweet spot.
We can’t wait for you to try it out! Please do check it out and let us know your thoughts—share them right here in Hexnode Connect!
George,
2 months ago Sep 23, 2026
Hi, I have tried out the new feature, as shown below for my kiosk app that is also in lockdown. However I finding that I still get the popup as you can see. I was hoping that the turning off the USB debug would prevent this popup. My Android is running as USB client, while the connected PI is running host. They need to be able connect without disturbing popups. Perhaps I am not understanding what this feature does or I need to turn developer off as well.
