Find win 11 recovery keySolved
5 months ago May 24, 2026
Hi everyone,
Need some urgent help with a Windows 11 Pro device. After a recent system update, one of our employee laptops suddenly booted into the BitLocker recovery screen and is now asking for the 48-digit win 11 recovery key.
The user has no idea where the key is stored, and the device won’t boot any further without it. We manage the laptop using Hexnode UEM, so I wanted to check if there’s any reliable way to find the win 11 recovery key either from the portal or somewhere else tied to the device history.
Has anyone run into this before?
Yeah, if the device is already locked on the blue BitLocker screen, you won’t be able to retrieve the win 11 recovery key directly from the laptop itself because Windows isn’t loading. The first thing I’d check is whether the device was signed in using a Microsoft account. If yes, Microsoft often stores the BitLocker recovery key automatically.
You can check it from another device here:
https://account.microsoft.com/devices/recoverykey
Sign in using the same Microsoft account associated with that laptop.
We had a similar issue last month with two Windows 11 devices after patching.
In our case, the win 11 recovery key was available in Hexnode because BitLocker had originally been enabled using a Hexnode encryption policy. You can verify it from: Device Summary > Hardware Info in Hexnode portal. The recovery password should appear there if escrow worked properly during encryption.
5 months ago May 25, 2026
One important thing to note here is that Hexnode can only display the win 11 recovery key if BitLocker was managed through Hexnode policies. If the user manually turned on BitLocker before enrollment, or encryption was enabled locally through Windows settings, the key might never have been uploaded to Hexnode at all.
5 months ago May 26, 2026
Thank you everyone. The win 11 recovery key was listed in the portal exactly as mentioned. Really appreciate all the help.
