Combining views in Patches dashboard?Solved
7 months ago Apr 22, 2026
Hi, I’m trying to get a consolidated view in the Patches dashboard where I can see device counts both device-wise (like laptops and mobiles by OS) and group-wise (for example, different branch companies) all in one place.
Right now, I’m unable to find a way to combine these views. Ideally, I want something that shows how many devices are present per OS and also how they are distributed across different groups, directly within the Patches tab. Is this possible?
Hi @arthur,
Currently, the Patches dashboard is designed specifically for managing patching on supported platforms, which are Windows and macOS devices. As a result:
  • Device counts for platforms like iOS and Android are not available within the Patches tab.
  • Group-wise device count breakdowns are also not supported in this view.
  • While you can apply platform-based filters, combining device type, OS, and group-level insights in a single dashboard view is not supported at the moment.
Alternative approach:
You can achieve a more customized view by navigating to: Reports > Custom Reports
Here, you can:
  • Apply filters based on device platform (Windows/macOS)
  • Segment devices by groups (such as branch offices or departments)
  • Generate reports that closely match your requirement for both device-wise and group-wise visibility
This approach provides more flexibility compared to the Patches dashboard.
Please give this a try and let us know how it works for your use case—we’ll be happy to assist further if needed.
