Changing the hostname of a macOS device from HexnodeSolved
13 hours ago Nov 13, 2026
I’m managing macOS devices in Hexnode and need to change the computer name/hostname of a Mac. I was looking for a remote action to rename the device, but I can’t find a direct option for macOS. Is there a way to do this from Hexnode?
2 hours ago Nov 13, 2026
For macOS devices, the hostname cannot be changed directly using the standard Hexnode remote actions.
The recommended approach is to deploy a custom script to the Mac. A typical rename script sets the macOS ComputerName, LocalHostName, and HostName values using scutil.
Example:
‍Replace <new-hostname> with the required name, then deploy the script to the target macOS device from Hexnode using the custom script deployment option.
Note: LocalHostName should not contain spaces or unsupported special characters. If the computer name has spaces, use a simplified version for LocalHostName.
