More Than Just an Uninstall: Automate macOS App Cleanups with Custom Scripts, Sequence & Modes!Solved
4 months ago Jul 21, 2026
Ever wished you could automate macOS app removals with custom cleanup scripts, a tailored execution order, and zero pop-ups or user interruptions?
Managing software on macOS just got a whole lot easier! We’ve added App Uninstallation as a dedicated action under the Automate tab in Hexnode UEM, giving you advanced, end-to-end control over your Mac app removal workflows.
Key Highlights
  • Multi-App Selection
    Remove multiple apps in one go. Pick as many applications as you need in a single automation task instead of setting up repetitive steps for each app.
  • Pre-Uninstall, Post-Uninstall, and Audit Scripts
    Clean up leftover files using your own custom logic. Attach pre-uninstall, post-uninstall, and audit scripts to stop background processes, clear lingering preference files, and double-check that the removal succeeded.
  • Customizable Uninstallation Flow
    Set the exact removal order. Choose which apps get uninstalled first so helper tools and dependent background services close smoothly without errors.
  • Configurable Mode of Uninstallation
    Remove apps quietly. Use the new Mode of Uninstallation setting to enforce silent background removals with zero pop-ups or distractions for end users.
Ready to take the hassle out of software removal? Head over to Automate in your Hexnode UEM console and set up your first app uninstallation action today!
