Android kiosk devices non-compliant due to missing Required AppsSolved
3 weeks ago Nov 06, 2026
Some of our Android tablets in kiosk mode are showing out of compliance because of missing mandatory apps. The apps listed include Hexnode Remote View and codes.simen.l50notifications. When I try pushing the app from the policy, it does not complete on a few devices, though other tablets are fine.
One affected model is a TCL 8 Plus. I removed Hexnode Remote View from the Required Apps policy, but I do not see any uninstall event in the action history, and the compliance error has not cleared yet. What is codes.simen.l50notifications, and what is the correct way to clear this missing app compliance status?
Hi @felixfrost ,
For Android kiosk devices, missing required app compliance is usually tied to the apps configured under the policy’s Required Apps list.
In this case, there are two separate points to check:
1. Hexnode UEM Remote View compatibility
Hexnode UEM Remote View is intended for Samsung Knox-supported devices. A TCL 8 Plus is a non-Knox Android device, so Hexnode UEM Remote View should not be kept as a required app for that model. If it remains in the Required Apps list, deployment can fail and the device may be marked non-compliant.
2. codes.simen.l50notifications
codes.simen.l50notifications is the package name for a third-party app called Heads-up Notifications. If this package is listed as a required app but is not installed on the tablet, Hexnode UEM will continue to report the device as non-compliant.
To clear the missing app compliance alert:
  • Go to Policies.
  • Open the Android kiosk policy assigned to the affected devices.
  • Click Modify.
  • Navigate to Android > App Management > Required Apps.
  • Remove codes.simen.l50notifications if the app is no longer required.
  • Also remove Hexnode UEM Remote View from the same list for non-Knox Android devices if it is not compatible with that model.
  • Save the policy.
After saving the policy, run both actions on the affected devices:
  • Scan Device
  • Scan Applications
Then refresh the device details page and check the compliance status again.
That explains part of it. I had removed Hexnode UEM Remote View, but I did not remove codes.simen.l50notifications. I was expecting an uninstall action to appear after removing the app from the policy, but nothing showed up in the action history.
Removing an app from Required Apps does not trigger an uninstall command. That section only controls whether Hexnode should treat the app as mandatory for compliance.
So if the app was never installed on the device, there will be no uninstall event. Removing it from Required Apps simply tells Hexnode UEM to stop checking for that app as a compliance requirement.
If the device still shows the same missing app alert after the policy change, confirm that the exact package codes.simen.l50notifications is removed from the policy and then run Scan Device and Scan Applications. The compliance status should update after the latest device and app inventory is synced.
I ran into something similar. The missing app warning did not disappear immediately after editing the policy. It cleared only after I manually triggered both scans from the device actions menu.
Hi @oliver_p ,
If an encryption compliance error remains after fixing the missing app issue, treat that as a separate compliance item. App scans will not clear encryption-related non-compliance.
For encryption alerts, either:
  • Enable device encryption on the affected Android devices, if encryption is required by your organization, or
  • Review the compliance settings in the assigned policy and remove or adjust the encryption requirement if it should not apply to those devices.
Once the encryption setting is corrected, run Scan Device again to update the compliance status in the Hexnode UEM portal.
