Android Enterprise vs Standard Barcode Enrollment for Android DevicesSolved
3 weeks ago Nov 06, 2026
I’m comparing the two Android enrollment options in Hexnode: Android TV & Standard Device enrollment and Android Enterprise enrollment.
For Android Enterprise, the device has to be factory reset and enrolled during setup by tapping the setup screen multiple times and scanning the QR code. But with the Standard Device option, I can install the Hexnode app from Google Play, scan the enrollment barcode, grant permissions, and enroll the device without wiping it.
I tested the barcode method on a device and the policy I had configured seemed to apply the same way as it did after Android Enterprise enrollment.
If the device can be managed without a reset, why is factory reset required for Android Enterprise? Also, is barcode enrollment a good option for Android devices that are already deployed in production and do not currently have an MDM installed?
Hi @hugo_l , The difference is mainly the Android management model used during enrollment.
Android Enterprise enrollment for fully managed/company-owned devices sets Hexnode UEM as the Device Owner during the initial Android setup process. Android only allows a Device Owner to be assigned before the device is set up, which is why a factory reset is required. Once enrolled this way, Hexnode UEM gets deeper OS-level control over the device.
Standard Device or barcode enrollment does not require a factory reset because it enrolls the device after setup, usually through the Hexnode UEM app with device administrator permissions and other user-granted permissions. This is useful for devices that are already in use, but it does not provide the same level of ownership or control as Android Enterprise Device Owner enrollment.
In practice:
  • Android Enterprise fully managed enrollment is recommended for new or company-owned devices where strong control, security, kiosk enforcement, and silent app management are required.
  • Standard barcode enrollment is useful for already-deployed devices where wiping the device is not practical.
  • Some basic policies may appear to work the same in both methods, but advanced restrictions and management capabilities can differ.
  • With Standard enrollment, the device remains more user-dependent, and some controls may require permissions to be granted manually.
For production devices already at customer locations, barcode enrollment can be a practical approach if the required policies work in that mode. If the deployment requires maximum lockdown and full Android Enterprise capabilities, the devices should ideally be reset and enrolled as Android Enterprise fully managed devices.
That makes sense. In my test, the policy worked after barcode enrollment, so I was wondering whether there is any real downside. Is it possible that only certain restrictions behave differently?
Yes. It is possible for the same policy to appear successful if it only uses controls available to both enrollment types.
The limitation becomes clearer when you need deeper management capabilities, such as stronger kiosk lockdown, silent app installation or removal through managed app deployment, stricter system restrictions, or controls that require Device Owner privileges.
With Android Enterprise fully managed enrollment, the MDM is provisioned as the device owner at the OS level. With Standard barcode enrollment, Hexnode UEM manages the device after setup, so Android does not grant the same authority. Users may also retain more control over the device depending on the permissions and Android version.
So the best method depends on the required policy set:
  • If the device is new or can be wiped, use Android Enterprise fully managed enrollment.
  • If the device is already deployed and wiping it would disrupt operations, use barcode enrollment, but validate the required policies first.
  • If any required restriction is not supported in Standard enrollment, plan a phased reset and re-enrollment into Android Enterprise.
