Add a PDF guide as an iOS home screen icon and arrange web clipsSolved
3 months ago Jul 13, 2026
We want to place a PDF user guide on our managed iOS tablets as an icon on the home screen, similar to a web clip. We already have a few web links deployed and would like the PDF guide and those web clips to appear on the first home screen instead of showing up after the other apps. Is there a way to add a PDF as an icon and control the icon order through Hexnode?
You can add a PDF to the iOS home screen by deploying it as a web app or web clip. The PDF needs to be hosted somewhere accessible through a URL. For example, you can upload the PDF to a cloud storage service such as Google Drive, OneDrive, or another approved hosting location, then generate a shareable or direct link to the file. Use that URL while creating the web app/web clip in Hexnode and deploy it to the devices through an iOS policy.
For arranging icons on supervised iOS devices, use the Home Screen Layout configuration in the iOS policy. This lets you place apps and web clips in a defined order across home screen pages. The usual path is: Policies > iOS > Home Screen Layout.
Or, if you are editing an existing policy: Policies > select the policy > Manage > Modify > Configuration > Home Screen Layout
Once configured, the policy can place the PDF web clip and other web links on the first home screen.
3 months ago Jul 14, 2026
I found the Home Screen Layout section inside the existing iOS policy, but the option is greyed out and I can’t select or edit it. Does that mean it’s not available for all accounts?
Yes, if the Home Screen Layout configuration is visible but greyed out, it usually means that the feature is not included in the current Hexnode plan. You can still deploy the PDF as a web clip if web app deployment is available in your plan, but you will not be able to enforce the exact home screen position or move it to the first page using Home Screen Layout unless that feature is included. Without Home Screen Layout, iOS may place newly deployed web clips after existing apps, so users might need to swipe to another page to find them.
