Which plan is required for Linux management?Solved
8 months ago Apr 14, 2026
Hi everyone, we’re planning to start managing a few Ubuntu devices through Hexnode. Does anyone know which subscription plan is needed for Linux device management?
We‘re managing Linux devices as well, and we’re on the Ultimate plan. It works, but only a limited set of policies are included at that level. For more advanced features, I think a higher tier might be required.
Oh no, we’re currently on the Enterprise plan 😕
Hey all!
Linux device management starts with the Ultimate plan. However, certain advanced policies and configurations require the Ultra plan for access.
@pepijn, if you’re considering an upgrade to enable Linux management, you can reach out to support@hexnode.com, and the team will help you with the next steps.
