Say goodbye to login headaches: Hexnode Access is almost here for Linux!Solved
2 months ago Sep 21, 2026
Managing sign-in on Linux endpoints usually means juggling separate local credentials with no centralized identity control. That’s about to change.
We are extending Hexnode Access to Linux devices, bringing the same identity-driven login control you already know from other platforms to your Linux fleet. Users will be able to sign in right from the greeter with their work account, with credentials securely verified through your organization’s Identity Provider and local accounts automatically linked behind the scenes.
We’re putting the finishing touches on this release. Keep an eye on our Release Notes — the rollout is just around the corner!
