Hi @harold ,
For Android kiosk devices, the kiosk launcher icon size can be changed from the Android kiosk policy.
Go to:
Policies > select the existing Kiosk policy > Kiosk Lockdown > Android > Launcher
Enable Customize kiosk launcher, then use the Icon Size option to choose the required size.
Medium is generally recommended as a best-practice setting because it keeps app icons readable across most Android screen sizes. Small can also be used if the kiosk has many apps or if the device screen layout requires more space.
For the FasterQ app not appearing in the Apps tab, the available method depends on the Android enrollment type:
- Android Enterprise enrollment: Add the app as a Managed Google Apps.
- Generic Android enrollment: Try adding it as a Store App and select the Play Store region where the app is available.
Some Play Store apps may not appear in search if the selected region does not match the app’s availability.
