Can Hexnode API detect APNs certificate or VPP token expiration?Solved
2 months ago Sep 09, 2026
Is there a way to use the Hexnode API to check when an APNs certificate or VPP token is close to expiring? We want to trigger our own notification before anything expires, ideally through an automated workflow instead of manually checking the portal.
Hello @_ashur ,
Hexnode currently does not provide API endpoints to detect the expiration date of APNs certificates or VPP tokens, and there is no API-based trigger available for sending custom expiry notifications.
For APNs certificates, Hexnode automatically sends email notifications to administrators before the certificate expires. The notification is sent 30 days before the APNs certificate expiration date.
For VPP token expiration monitoring through the API, there is currently no supported endpoint or notification trigger available.
I have a thing to ask, can BitLocker recovery keys be exported through the Hexnode API?
BitLocker recovery keys cannot currently be exported using the Hexnode API. Administrators can view and retrieve BitLocker recovery keys directly from the Hexnode UEM portal, but API-based export is not supported at this time.
