We are getting an error on enrolling an Iphone device:- ‘Apple’s MDM Certificate (APNs) is required for enrolling Apple Devices. Please contact Administrator’
You will have to create an APNs certificate for enrolling Apple devices. For communicating with the device, the MDM will send a notification to the APNs server and the server will then communicate with the device. Hence, the APNs certificate is essential.
For creating an APNs certificate:
Kindly use the help doc on APNs certificate creation for more info.
I was trying to add APNs certificate as mentioned above. But I got the following error from Apple Push Certificates Portal.
“To get a new certificate for a OS X server, use your OS X server administration tools.”
The probable cause for this error is that the Hexnode link goes to https://identity.apple.com/pweb/ which should go to https://identity.apple.com/pushcert/. This may also happen due to an incorrectly terminated session.
To solve this:
Please check out our troubleshooting doc on configuring the APNs certificate for more help.
