Feature request: Turn Mobile Data on/off
expand collapsive
Feature request: The ability to enable/disable mobile data either through a per device/group action or through a policy update.
We have 15 Android 5.1.1 based ticket scanners. They normally connect to the server over WIFI but about 2-3 times a year they are used outside where the is no WIFI coverage and it would be really helpful if we could enable mobile data before these events and then disable it immediately afterwards.
All Replies
  • Hey Christian!
    I’m afraid it’s not feasible to force enable mobile data on Android devices. It can be disabled via policy restriction on Samsung Knox, LG GATE, and Kyocera business phones alone from Policies > New Policy > Android > Restrictions > Allow Network Settings > Mobile data. Once disabled via policy, mobile data would remain disabled even after the policy is removed off the devices. It’d have to be manually enabled.
    An alternative we’d suggest is configuring multiple open Wi-Fi networks from Policies > New Policy > Android > Networks > Wi-Fi (Security type – None) and push it to the devices. This way, even if the devices are out of any of the previously configured Wi-Fi networks’ coverage, a Wi-Fi hotspot can be set up with any of the configured SSID, and the device can be brought online. If you have any safety concerns, once you have the devices back in hand online, you can delete the Wi-Fi profile used and use another one the next time around.
    Hope this helps!
    Do look through the latest feature updates and what’s cooking here at Hexnode MDM!
    Amy Watson
