What exactly is the .DS_Store file?Solved
1 year ago Feb 15, 2025
While organizing some project folders to send to a client, I noticed a hidden file named .DS_Store popping up in almost every directory. At first, I thought it was some kind of virus or leftover system junk, but it kept reappearing, even inside zipped folders I was preparing on my Mac. Can anyone tell me what it is?
Hidden .DS_Store files found on macOS devices
1 year ago Feb 17, 2025
Yeah, I’ve run into that too when prepping files for shared drives. Turns out it was .DS_Store (Desktop Services Store). macOS creates it automatically when you open a folder in finder. It keeps track of how you view a folder, like icon positions, window size, and view settings.
1 year ago Feb 18, 2025
Oh okay. But the annoying part is that when I transferred the zip to a windows system, those .DS_Store files were visible and it confused the client.
1 year ago Feb 20, 2025
Totally understandable. If you’re sending files to someone not using a mac, it’s better to clean those up first. You can open terminal, navigate to the folder, and run:
rm .DS_Store
1 year ago Feb 23, 2025
And if you’re dealing with shared network folders or external drives regularly, you can stop macOS from creating those files on network volumes with this command: defaults write com.apple.desktopservices DSDontWriteNetworkStores true
Just make sure to restart your mac afterward.
1 year ago Feb 27, 2025
Good to know. I’ll be adding that step to my prep process going forward. It saved me a bit of embarrassment this time.
