My laptop wakes up slower after a long idle timeSolved
1 year ago Feb 24, 2025
I noticed when I close my laptop lid, it goes to sleep and wakes up instantly. But when I leave it idle for a while, it takes longer to wake up. Why does it behave differently?
1 year ago Feb 27, 2025
That’s because your device can enter different system power states depending on how long it’s inactive. Windows uses six power states, S0 through S5, to manage power and performance.
Think of it like this:
  • S0 is when everything is on and running, normal usage.
  • S1 to S4 are various sleep states. The deeper the state, the less power used, but also the longer it takes to resume.
  • S5 is full shutdown. Your system is completely off, and it has to boot up from scratch.
Each state is characterized by the following:
  • Power consumption: How much energy the computer uses in that state?
  • Software resumption: At what point the operating system resumes or restarts?
  • Hardware latency: How long it takes for the computer to return to a fully working state?
  • System hardware context: How much of the system’s hardware information (like processor registers, memory caches, and RAM) is preserved. Does the operating system need to reboot to resume work?
1 year ago Mar 02, 2025
Okay, so sleep isn’t just sleep? There are levels?
1 year ago Mar 07, 2025
Exactly. For example, S3 powers down most components but keeps memory active. So, when you wake it, your apps are still right where you left them.
But say your device enters S4, also called hibernation. That’s deeper. Your current session is saved to disk, so you can resume it later, but it takes longer to wake. Useful for conserving more battery, like overnight or during travel.
1 year ago Mar 10, 2025
And S5 is just off?
12 months ago Mar 12, 2025
Yep. Nothing is retained. Your device starts clean, just like powering on after a shutdown.
