What exactly are linux distros?Solved
10 months ago Jun 14, 2025
I’ve been setting up a few linux devices lately, and I keep seeing terms like Ubuntu, Fedora, and Mint. They all say “Linux”, so what’s the real difference? Aren’t they basically the same thing under the hood?
Replies (6)
9 months ago Jun 18, 2025
Pretty much the same foundation, they all use the linux kernel. But a linux distribution (or distro) is more like a complete operating system built around that kernel. Each one comes with its own tools, libraries, interface, and package manager. So while they all speak “Linux”, the dialects are a bit different.
9 months ago Jun 23, 2025
And those differences are pretty noticeable when you start using them. Ubuntu and fedora are general-purpose distros that work well on desktops and servers. Kali linux is all about security testing, while centOS is designed for server stability. So, they share the same foundation, but the way they’re put together makes them behave quite differently.
9 months ago Jun 29, 2025
So if we’re managing linux devices through Hexnode, does it matter which distro the device is running? Or is it all treated the same way once enrolled?
9 months ago Jul 01, 2025
It does make a difference. Hexnode supports a few specific versions like Fedora 36+, Ubuntu 18.04+, Debian 10+, and MintOS 21+. Each distro handles system management a bit differently, so the platform needs to align with that structure for things to work properly.
9 months ago Jul 10, 2025
And even among those supported ones, not every policy works everywhere. For instance, the password policy in hexnode functions on Ubuntu, fedora, and debian, but it isn’t supported on MintOS.
9 months ago Jul 14, 2025
That explains a lot. I used to think “Linux is Linux”, but turns out each distro brings its own quirks and that definitely matters when you’re trying to manage them at scale.
