How does ‘Ping’ Test Website Connectivity?Solved
6 months ago Oct 04, 2025
Hello,
I’m troubleshooting some connectivity issues with a few remote devices and wanted to verify if our websites are reachable. We have our own websites running algorithms on these remote devices, and I want to check their connectivity. I searched online and saw the ping command might help. Could someone explain how to use it and what the results mean?
6 months ago Oct 05, 2025
The ping command is one of the easiest and most reliable tools to test whether a website or a network host is reachable.
Here’s how you do it:
On Windows, open Command Prompt and type:
ping http://www.example.com
On macOS or Linux, open Terminal and do the same.
The command sends a series of small data packets AKA Internet Control Message Protocol (ICMP) Echo Requests to the website’s server. If the server is reachable, you’ll get back ICMP Echo Replies along with the response time in milliseconds.
For example:
Received from 93.184.216.34: icmp_seq=1 bytes=32 time=20ms ttl=58
This means the website responded in 20 milliseconds, a pretty healthy connection!
Actually, these numbers can tell you quite a lot.
  • time=XXms → The round-trip time for the packet. Lower is better.
  • TTL (Time to Live) → How many hops (routers) the packet went through.
  • Request Timed Out → The server didn’t respond — could be down, blocking ICMP, or your network has issues.
A lot of people don’t realize some websites intentionally block ping requests for security reasons. So, if you get a timeout, it doesn’t always mean the site is offline.
Ah, that makes sense. I just tried ping google.com and it’s replying fast, but when I tried pinging a couple of internal websites, they timed out. Guess those might be blocking ICMP or behind firewalls.
6 months ago Oct 06, 2025
Exactly. For internal sites, that’s quite common. Think of ping as your first checkpoint. If ping fails, you know there’s a network path issue. If it passes but the website still doesn’t load, then the problem is probably with DNS, the web server, or a firewall rule.
In enterprise setups, ping is essential for quick checks on device or server reachability. It really helps streamline the troubleshooting flow. In my experience, the simplest tools are often the best for the job!
