Logging into Windows devices has never been easier!
With Hexnode Access you can effortlessly login to your Windows using your IdP cloud credentials. Whether you opt for your Microsoft Entra ID or Google Workspace credentials, logging in is seamless. And that’s not all, there are a bunch of accompanying features too.
Want to personalize the login screen with your organization’s logo? Consider it done!
Want to allow users to connect to a network from the login screen? No problem!
Want to attach help links on the login screen to aid users during onboarding? Easy!
Want to execute custom scripts on login? You got it!
Hexnode Access encompasses all these functionalities and much more. We cannot wait to introduce the feature to you. In the meanwhile, stay tuned and check out our
latest feature releases.
