How can I use the Android Kiosk in Hexnode MDM?
Hi Tim,
Hexnode MDM allows you to lock your device(s) in either Single App Mode or Multi App Mode.
Requirements:
- The device must be enrolled with Hexnode MDM.
- The device should have an active internet connection.
Perform the following steps to enable Kiosk mode in Android devices.
1.Log in to your Hexnode MDM Console.
2.Navigate to Policies > New Policy.
3.Click on Android Settings > Kiosk Settings.
4.Click on Single App Kiosk if you wish to lock down devices to a single app or click on Multi App Kiosk if you wish to restrict your devices down to a handful of apps.
5.Click on Configure.
Hexnode MDM integrates other useful features into kiosk mode such as
Background Apps – Hexnode MDM allows you to hide app icons in Kiosk mode.
Auto Launch Settings – Auto Launch Settings enables you to set an app as default app.
Peripheral Settings – Peripheral Settings allow you to configure Wi-Fi, volume, brightness and so on.
Kiosk Exit Settings – Kiosk exit settings enables you to set passwords to exit from kiosk.
Hexnode Browser Settings – Hexnode Browser Settings enables secure browsing by restricting access to whitelisted URL’S or web apps added in kiosk mode.
Miscellaneous Settings – Miscellaneous Settings enables Hexnode Messenger and User Location Check-in.
One you are done using the Kiosk mode, you can easily exit from the kiosk mode.
The video below explains how to exit from Kiosk mode.
- This reply was modified 5 years, 7 months ago by Frank Clinton.
7 August 2018
