Unsupported Screen Size: The viewport size is too small for the theme to render properly.
App deploying in iOS
Unified Endpoint Management Community Forums General App deploying in iOS
  • This topic has 1 reply, 2 voices, and was last updated 3 months ago by Grace Baker. This post has been viewed 58 times
Viewing 2 posts - 1 through 2 (of 2 total)
  • Author
    Posts
  • #4071 Score: 0
    Helen
    Is there a way to deploy an app with login creds pre-applied?
    #4152 Score: 0
    Moderator
    Hi,
    Thanks for posting the question.
    This will be dependent on the app you wish to deploy.
    Kindly navigate to the ‘Apps’ tab and click on the desired app. The App details will appear and click on the gear icon at the top right corner. Choose the ‘App Configuration’ from the drop-down list. On enabling the ‘Update App Configuration’ option, an option to upload an XML file will appear. An option to download a sample XML file will also be found alongside.
    The login credentials for the app can be given through this XML file. But this is dependant on whether the app allows this feature.
    Hope this helps!
  • You must be logged in to reply to this topic.
