Unsupported Screen Size: The viewport size is too small for the theme to render properly.
Android Zero-Touch Enrollment
Mobile Device Management Community Forums What’s Cooking? Android Zero-Touch Enrollment
This topic contains 0 replies, has 1 voice, and was last updated by  Frank Clinton 3 months, 4 weeks ago. This post has been viewed 145 times
Viewing 1 post (of 1 total)
  • Author
    Posts
  • #2441 Score: 0
    Frank Clinton
    1 pt
    The Zero-Touch Enrollment helps in out of the box EMM enrollment, rather than enrolling a device one by one.
    Do keep in mind that the devices suitable for Zero-Touch enrollment need to be purchased directly from a google partner or an enterprise reseller and not from a consumer store.
    Zero-Touch eliminates the need for users to manually configure the devices themselves.
    Advantages of Zero-Touch enrollment:
    – You just have to set it up once:
    Zero-Touch enrollment is a one-time process which is done at the initial setup.
    – Makes MDM Mandatory:
    Only works with a third party EMM.
    – Device would be set up and enrolled out of the box:
    With ZTE, the device would be enrolled to the emm right before the device’s initial boot.
    – Provisioned as Device Owner:
    Devices enrolled via ZTE would be enrolled as a device owner hence the device will be only for corporate use.
    – Easy setup for devices in bulk:
    With ZTE, you would not need to enroll the devices one by one, you can enroll devices all together in bulk thus saving time and increase productivity.
    The Zero-Touch enrollment by Google would be integrated with Hexnode soon, Making enrollment fast and seamless.
    Frank Clinton
    Hexnode MDM.
    • This topic was modified 3 months, 3 weeks ago by  Frank Clinton.
You must be logged in to reply to this topic.
